![]() | Home > Maintenance & Mods (L405) > Tailgate anti-trap sensors - testing |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16387 ![]() ![]() ![]() |
I believe they are torque variant motors. So, something gets trapped and the relevant amount of torque reverses the motors? Buy I could be completely wrong in my assumption…
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8084 ![]() ![]() ![]() |
I had a similar but different problem - but the process will be the same. That is, buy an ODB code reader & see what fault codes are being generated. That will point you in the right direction. You can also read the real time values from the sensors if required.
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
Not sure how if all model years have them, but pretty sure the later model years have the anti trap sensors in the sides of the upper tailgate.
Agree - the anti-trap on the lower tailgate should cause that to re-open - or in my case, not even try to close. There may also be a sensor that checks the lower tailgate is fully closed and it sounds like that's the case to me. Then there's anti-trap on the upper tailgate.
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 932 ![]() ![]() |
This was the case on my L405, I swapped all four sensors for new ones but still had an issue, I then decided to re-align the tailgate (and replaced the bolts that secure the upper hinges, there a TSB relating to this) and hey presto, it worked faultlessly. Jonathan 2010 L322 5.0 SC Autobiography Black 2007 Defender 90 XS Hardtop |
Richiesrangey Member Since: 17 Sep 2022 Location: Edinburgh Posts: 11 ![]() ![]() ![]() |
Thanks all for your advice and insights - all really helpful. I tested each anti trap sensor individually by starting the tailgates closing and squeezing the strips. All work fine one needed glueing back in place, nothing fowling them or any damage.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1411 ![]() ![]() |
Well a few days ago using the spare wheel removal system ![]() I stupidly forgot to remove the clamp from the upper gutter and closed the tailgate. Fortunately it stopped on contact and re-opened itself, so it must also have some sort of torque motor sensing! 2018 SE SDV8 4.4 Byron Blue |
Also in the WS manual section 501-03 there is a 60 page troubleshoot guide for upper and lower tailgate 2018 SE SDV8 4.4 Byron Blue |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8738 ![]() ![]() ![]() |
Check out this, it maybe the problem, maybe not but it's a free check...!!
To close this one off:
Good news & hopefully a permanent fix |
Great research and sharing of your problem- ![]() |
