![]() | Home > Technical (L405) > Ride quality -16 SDV8 AB |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3308 ![]() ![]() ![]() |
Just went to the start of the thread and you are still on 21" wheels with 45 profile tyres? Maybe worth seeing if you can borrow a set of 20"? I can tell mine get harsher with just 10% higher than stock tyre pressures and I can imagine a lower profile tyre would be harsher still. 2012 TDV8 Vogue (L322) |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 752 ![]() ![]() |
If I knew someone to borrow a set off then I would try them.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
is your tyre pressure set at light or heavy load..
Currently set at just below light load on the front 33psi and 33psi on the rear.
i meant the menu setting.. ... - .- -.
Sorry Stan my bad, in the dash it's currently set to light load. |
I suggest dropping the pressures to 25psi all round and going for a very gentle and short drive to see what it feels like. IME sidewall compliance is the main suspension component responsible for dealing with low speed road imperfections. 2012 TDV8 Vogue (L322) |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1511 ![]() ![]() ![]() |
Didnt know you could set the load setting on the dash? |
you have 2 options doc.. light or heavy , it should flash up when you start your engine.. ... - .- -.
Does a voltage drop to 9 volts when cranking seem okay/normal?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8746 ![]() ![]() ![]() |
Mine drops to high elevens and doesn't shoot up to over 15, its a new battery
That's interesting then... thanks so much for the comparison Haylands. |
Reading a review of the L460 and this is what they have to say about the L405.
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
“The L405 rides better than anything this side of a rolls Royce” |
