![]() | Home > My Range Rover > Engine Failure 4.4 SDV8 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
Sorry to hear that Martyn. You must be devastated. Hope you can find the cause and share what might have happened. |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 939 ![]() ![]() |
Gutting, could this potentially be submitted as an insurance claim?? Jonathan
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8770 ![]() ![]() ![]() |
Ouch..!! Deepest commiserations. That doesn't sound good, did you have to turn it off or did it stop on it's own..? Pete
Martyn Member Since: 10 Mar 2013 Location: Poole Posts: 65 ![]() ![]() |
Thanks all.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3874 ![]() ![]() ![]() |
Condolences Martyn, 4.4 tdV8 engine fails are very rare, so would be good if you find the cause and are able to share it with us.
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 157 ![]() ![]() |
Could that be turbos eaten themselves and caused the mess? Running on fuelled by its own oil? Especially as it started again and moved under its own power? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8105 ![]() ![]() ![]() |
I'd guess at sub-£10k as a non-runner.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3811 ![]() ![]() |
Sounds like one of the Turbos has gone and it’s running on on its own oil. If it still turns over, starts and runs then it’s not seized and very unlikely there is a hole in the block - it may not be that bad. We have tractors here with turbocharged 7.5 litre engines that have had similar failures and a replacement turbo at £800 sorted the issue - it was merely the bearings that had gone causing massive oil consumption and horrendous running. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
There seems to be quite a few SDV8 engine failures appearing on the L405 Facebook groups these days |
Which groups are these ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
I’ve seen 4 or 5 recently on Range Rover Owner L405 on Facebook.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1855 ![]() ![]() |
We've had a few in, all with failures after turbo issues... |
Mikey, do the turbo issues wreck the engine and are there any symptoms before the arriving doom...?? Ta.. Pete
