Home > Maintenance & Mods (L322) > Front Hub Strut Bolts - knock out or screw out?
Thumbs Up Bow down Thumbs Up Pete
-Click here for Thread-
Post #670992 11th Aug 2023 5:10pm
Ennoch
Superspoons wrote:
Can you recommend one from personal use Haylands ?
I'm hoping to get access to a 1000Nm cordless one .... if that doesn't do the job then .....
cheers
I've had a few of the older Snap on guns over the years which gave been fine but I never got them new and I've generally sold them on and upgraded when I've had the chance. I've got a new Bosch 1050 18V now as all my other cordless stuff is Bosch Pro so it reduces the amount of chargers and batteries I need and it's great. Just remember that if you do go for an impact wrench that you should use impact sockets with them, and that any extensions you add in to reach bits will reduce the impact's effectiveness. A good quality, thick and stiff breaker bar with some pipe on the end is a good bit of extra leverage. The trick that experience shows you is that some times it's better to use the big bar, and other times it's better to use the impact so that the bolt never stops unscrewing. Sometimes it'll gall up and take a lot of effort to get moving again, where the impact wrench would avoid that. Other times there's no replacement for a big sodding bar!
Post #671008 11th Aug 2023 10:20pm
Superspoons
Thanks for all your advice and recommendations Thumbs Up
I've added to my thread https://www.fullfatrr.com/forum/topic63354-90.html with how its going .... and its not good
 Gavin
https://www.youtube.com/@ChallengingClassics
Post #671016 12th Aug 2023 10:39am
p38arover
Australia
I’ve replaced both front struts and the bolts came out easily.
Ahh, the advantage of living where rust isn’t an issue (I have a 20 year old L322 with no rust). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #671029 12th Aug 2023 1:58pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
lots of wd40 and same tools as all overs used and a lump hammer Rolling with laughter
Post #671032 12th Aug 2023 2:49pm
MR GLOVER
last resort drill it out ?
Post #671033 12th Aug 2023 2:54pm
Superspoons
Update -
Got it out Thumbs Up
I’d tried a 6ft scaffold bar with a breaker - it just bent. In the end I heated the bolt for 5 minutes and then the thread on the nut side. A few good hits with a long sledgehammer on the nut at the end of the thread broke the rust on the bolt and it slowly slid out. New bolts going in so I didn’t worry about the state of the nuts.
 Gavin
Post #671155 14th Aug 2023 11:40am
Well done, excellent... Bow down
I hope you dipped the new one in salt water to make it as bad for the next owner... Thumbs Up Pete
Post #671156 14th Aug 2023 11:51am
Superspoons
Thanks - it was challenge but not as bad as the lower ball joint in the hub ...
That's just evil Rolling with laughter Gavin
Post #671162 14th Aug 2023 12:17pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Oh so satisfying when they come out Razz
Post #671164 14th Aug 2023 12:20pm
