![]() | Home > Technical (L405) > I bricked my car....2020 L405 |
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2770
Have you tried restarting the instrument cluster update?
| steve56 Member Since: 13 Jun 2020 Location: colorado Posts: 13
Everything was fine with downloading new firmware for all 3 modules.
I would disconnect the instrument cluster then see if any module can communicate. In various earlier vehicles the instrument cluster is connected to both the HS and MS canbus so could conceivably lock out both. |
Thank you Graeme! I’ll have my tech do that!
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
The gateway will be stuck in bootloader mode, don't worry about the IPK until you get the gateway to communicate. Worst case is a new gateway module. |
Sounds cheaper than a new IPK! |
My dealer is a god send and very helpful. They are following procedures that you guys suggested, so thank you so much.
| chezgky Member Since: 01 Sep 2025 Location: IL Posts: 1
Hi, may I know what ultimately fixed your issue? I did the same to my FPace SVR tonight and just registered here in hopes of finding a solution. Thank you in advance. |
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1053
Don't expect a reply that post is 2 years old and the op hasn't been back since |
