![]() | Home > Technical (L405) > I bricked my car....2020 L405 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
Have you tried restarting the instrument cluster update?
steve56 Member Since: 13 Jun 2020 Location: colorado Posts: 13 ![]() ![]() ![]() |
Everything was fine with downloading new firmware for all 3 modules.
I would disconnect the instrument cluster then see if any module can communicate. In various earlier vehicles the instrument cluster is connected to both the HS and MS canbus so could conceivably lock out both. |
Thank you Graeme! I’ll have my tech do that!
The gateway will be stuck in bootloader mode, don't worry about the IPK until you get the gateway to communicate. Worst case is a new gateway module. |
Sounds cheaper than a new IPK! |
My dealer is a god send and very helpful. They are following procedures that you guys suggested, so thank you so much.
