Home > Maintenance & Mods (L322) > TDV8 Turbo replacement
alxgreen
Hello everyone, I'm new here. I have a 2008 L322 TDV8 Vogue.
Unfortunately I've discovered my drivers side turbo actuator is moving but with a fair bit of resistance causing lower performance and 'engine system fault' code p132b.
It seems the passenger side has been replaced as it moved TOTALLY freely with zero resistance.
I'm based in Chester, Cheshire and was wondering if anyone has any recommendations for turbo replacement? I found somewhere in Birmingham but ideally if I can find somewhere more local it would be great.
I've tried freeing it up and lubricating but at this point the blades will be guked up.
Any help would be great
All the best
Post #672848 6th Sep 2023 9:18pm
garyRR
Been discussed on here many times before.
Birmingham Turbos will probably do it for a £1,000 or greater less than anyone else will quote you, assuming anyine else doesn't say no to the job anyway (in my experience, garages don't want this type of job, and you can waste days ringing round and chasing to no avail). 2015 Range Rover Autobiography 4.4 SDV8
Post #672853 6th Sep 2023 10:27pm
