Home > Maintenance & Mods (L322) > Well, we went on holiday, the FF didn’t like it…. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2784 |
If cost were no object I wouldn't get an L405 that's for sure. 2012 TDV8 Vogue (L322) |
3rd Sep 2023 12:03pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7645 |
Back from holiday. Moved car… no fault messages. Drove fine.
9th Sep 2023 4:48pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3655 |
I struggled with restricted performance off and on for a few months. Indy fixed it by cleaning the MAF sensor, I didn't mention to them that I had already tried it (because I probably it up) Geoff |
9th Sep 2023 5:54pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
I have had the water in fuel yellow restricted performance triangle come up a few times that often disappears on its own and is a common issue with the water in fuel sensor. But after sitting for a month due to waiting for rear brake lines to be fixed, when I picked it up, the yellow sensor came on and after filling with fuel it then came on with a red triangle that actually restricted the performance and limited the revs and speed.
9th Sep 2023 7:06pm |
Car is at the specialist, not seen the message since and it’s still driving fine.
13th Sep 2023 3:45pm |
https://www.fullfatrr.com/forum/topic67778.html 2012 TDV8 Vogue (L322) |
13th Sep 2023 3:50pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Check the pending codes too in your GAP. Sometimes points to an issue Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Sep 2023 6:44pm |
How many oxygen sensors does the 4.4 TDV8 have? Anyone know?
15th Sep 2023 2:50pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2282 |
just load it up again and make it think that you're going on holyday again...might trigger the isue..
15th Sep 2023 3:10pm |
I dare say it would 🤣. It’s bound to do it again, prob as the MOT man is looking at it…..
15th Sep 2023 7:04pm |
