Home > My Range Rover > Genuine Land Rover Parts |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1276 |
Put brembo discs and pads from euro car parts, no issues whatsoever, maybe I was lucky or its subjective bs. |
25th Aug 2023 12:16pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2762 |
There is nothing 'wrong' with Brembo pads or disks. 2012 TDV8 Vogue (L322) |
27th Aug 2023 6:52am |
I've got high speed brake judder on mine since fitting Delphi pads / Brembo ( LR branded) disks. Perfectly smooth disk surface and the runout was checked and still a mystery... 2012 TDV8 Vogue (L322) |
27th Aug 2023 1:57pm |
My LR branded Brembo front disks are officially warped (as tested by Glenrands) Apparently I'm not the first example of LR warped disks. No idea how this has happened as I'm super careful when braking on a new disk/pad instal and that's on top of my very gentle driving style. Think I'm going to replace with non LR/Brembo disks....... 2012 TDV8 Vogue (L322) |
29th Aug 2023 6:59pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Usually failure to clean the hub mating surface or badly refurbished wheels (excessive paint on the mating surface or damaged wheel) causes the discs to distort when cooling. Occasionally a sticking brake caliper piston can cause excessive heat on one side of the disc, this will also cause distortion upon cooling, the effect is cumulative. |
29th Aug 2023 8:44pm |
Nice to see you back Phoenix
30th Aug 2023 9:23am |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 149 |
I went Pagid in the end. So far so good, no squeaks or squeals and the car stops! |
11th Sep 2023 6:00pm |
Had pads and disks replaced this morning with Borg & Beck so once they are bedded in I'll report back. 2012 TDV8 Vogue (L322) |
11th Sep 2023 6:05pm |
Super Sloth Member Since: 23 Jun 2020 Location: Derbyshire Posts: 25 |
There’s a time to use genuine and a time to use 3rd party.
1st Oct 2023 6:12pm |
AFAIK no major car manufacturer makes their own brake parts and they are all sourced from specialist suppliers such as ATE, Brembo, TRW etc. 2012 TDV8 Vogue (L322) |
1st Oct 2023 7:10pm |
Likely to be that answer to a lot of things? Sanden on compressors / Pirelli on tyres / Philips er Al on bulbs etc…
1st Oct 2023 7:55pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1060 |
I have just purchased Brembo Front & rear discs. £129 rears and £150 front just waiting for brembo front pads to reduce in price.They have a nice painted hub and vents ,at least they look good. overfinch modified |
2nd Oct 2023 4:05pm |
The Borg&Beck disks and pads are working out well for me. Nice bite and progressive braking feel, low dust and no noise and more importantly no more judder. Still no idea why the Brembo disks warped so quickly or maybe even were warped out of the box although I do know that cast products can warp due to machining too quickly after casting. May fit B&B pads on the rears as it's an easy enough job. 2012 TDV8 Vogue (L322) |
2nd Oct 2023 4:22pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7929 |
I use Diamond, best pads ever....
2nd Oct 2023 5:28pm |
