![]() | Home > Technical (L322) > Rear pinion seal replacement |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
Check that the breather isn't blocked if not already done. |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 68 ![]() ![]() ![]() |
I will indeed. Where is it located, if you don't mind? |
Microcat 2012 shows it running up high, probably with the fuel filler pipe. |
