![]() | Home > In Car Electronics (L322) > Upgrading the reversing camera to a better quality output? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
When I had the Jaguar XJL last week I noticed the reversing camera was incredibly clear, not slightly fuzzy as in the FFRR.
HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244 ![]() ![]() ![]() |
you can upgrad to a 2010 camera.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
The reverse camera in the MY2010 RR that I borrowed for a week was much clearer than the one in my 2006. |
But the 2010MY cars also have the newer screen, whiich could help too. Discovery 4 HSE
DVDs look great on my 2006 screen, which indicates the camera is the weak point. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35762 ![]() ![]() |
you'll probably find the original cameras were cmos type and the later ones ccd type which are considerably better.. |
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 ![]() ![]() ![]() |
I hooked up my after-market rearview camera (expensive) to another screen and picture was super sharp. This indicates our 2006 screen is poor in quality! '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
they are different cameras, the first cameras were cmos 380 lines, jumping to 420 later but still cmos, not a great pic, the 2006 and on used ccd instead of cmos this gave a better pic and had the same plug but on the 2010 use a hd camera and will give a far better pic.. but will not fit on to the earlier cars as it has 4 pins plus video and the earlier cars only have 2 pins plus video
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Mine is a late 2006 registered 2007 MY TDV8, is the camera in that the best available? |
you will have the ccd version, you wont get any better then that factory wise but if you fitted a after market you could get far better but it would have to be made fit, you can get cameras 540 lines and that will switch to black and white at night giving you 600 lines, you can fit extra ir leds behind the reversing light that will come on with reverse and light up whats behind you. V8 facelift Range Rover Autobiography 22" wheels.
THere was a very useful thread on here recently with step by step instructions and photos on replacing the rear view camera - I cannot find it |
Gaz did you get yours sorted.. V8 facelift Range Rover Autobiography 22" wheels.
Just replaced the camera in just 30 minutes start to finish.
i knew it could only be the camera or the loom as the system was working fine, it see when you selected reverse.
