Home > Technical (L322) > If my supercharger is coming off, what else should I do?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Potentially my supercharger is coming off.
Should I replace those coolant pipes that run underneath at the same time or is that not needed?
Anything else?
Post #674400 27th Sep 2023 6:18pm
David on here is your man on here to talk to, he’s done a lot of SC work on both 4.2 and 5.0 Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #674412 27th Sep 2023 8:25pm
dingg1
I would, probably past their best and ideal opportunity to do so at not much cost
Post #674424 27th Sep 2023 11:11pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
IMHO yep change them, bit like if you remove a gearbox from a manual then replace the clutch
Again in my opinion when changing any major component replace any minor components that are uncovered you will not regret it until you don't do it!
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #674431 28th Sep 2023 2:35am
dhallworth
There's a rubber hose that runs under the Supercharger which is part of the hoses mounted to the aluminium bracket which is secured to the rear left of the engine as you look at it. If you buy that pipe from Land Rover it was around £300 in 2022. However, the part is made by Gates and is available in a Gates bag for £100 (or it was in 2022!). Rob at Duckworth Land Rover supplied me with the Gates one.
I'd also change the oil in the Supercharger, the water pump, both drive belts and the thermostat.
All of the idlers on the front of the engine are metal pulleys so you can replace the bearings in them. There are 2 pulleys and 2 tensioners, the pulleys unbolt from the tensioners and you can change the bearings in them too. I ordered 4 xSKF 6203-2RSH bearings online and changed all of mine. Cost less then £20 and meant everything was running lovely and quiet.
Whilst you've got the fan and shroud removed I'd probably put a new gasket behind the oil filter housing where it bolts to the front of the block as well.
All the work I did on mine is detailed in here:
https://www.fullfatrr.com/forum/topic57991.html
Picture of Supercharger removed on page 6, you can see the 2 pipes under it.
If you're looking for parts diagrams, part numbers or prices then this website is a fantastic resource:
https://parts.jaguarlandroverclassic.com
Post #674449 28th Sep 2023 2:03pm
philip1972
Thanks David. I have recently had a new water pump, all the pulleys and tensioners as new belts, so I will go with the pipes under the charger 👍
Post #674468 28th Sep 2023 5:24pm
dhallworth
I replaced mine purely whilst I was in there but the old ones looked despite being 15 years old at the time. They’re rubber rather then hard plastic so they don’t go brittle. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #674495 28th Sep 2023 8:57pm
Super Sloth
Any vac hoses you cannot easily get at should be renewed. Vac leaks cause a lot of problems on vehicles of this age.
Post #674714 1st Oct 2023 8:24pm
