![]() | Home > Maintenance & Mods (L405) > Sway bar end link trials |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
Dont take this as a flame.
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 256 ![]() ![]() ![]() |
The thread pitch is finer. That may affect a max torque to failure rating; however, 185 NM is the spec and far below the max torque to failure rating. The stud size remains the same.
You don't need to compress the suspension to torque up the droplinks - they're ball joints so will turn as the suspension moves.
Thanks. Regardless of compression, I have difficulty getting them to stop spinning to reach torque. The Moog parts worked perfectly to torque. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
All we use for jobs like that is one of these in the torque wrench
Thank you!
Those 'plug in' to the torque wrench in place of the ratchet head, you can get versions that are essentially a ring version of a crowfoot wrench that has a 1/2" square drive hole in it.
Thank you so much. I had not seen interchangeable head tools before.
Just check the ratchet assembly is removable - not all are, there will be a ~4mm hole where you can insert a pin to depress the spring loaded locking peg. |
