![]() | Home > My Range Rover > New to me: L322 4.4L TDV8 Vogue SE |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Get the oil cooler sorted ASAP is my advice.
| bluebottle Member Since: 16 Apr 2021 Location: The M3 Corridor Posts: 157
I already have done Rob - Tom Lenthall did it along with some suspension work. 2012 L322 TDV8 Vogue SE: Buckingham Blue
Second MoT in my care, passed although with an advisory for leaking oil... the guy was most unhelpful "It was around the transmission, not too bad so I didn't put 'excessive'."
I’d be double checking the oil cooler hasn’t started leaking again for some spurious and annoying reason despite the O rings being replaced and oil cooler plus it’s gaskets (I assume they replaced the cooler and not just gaskets??). Cooler can warp apparently so if you put new gaskets on a warped cooler it will still weep.
Just a quick update post - I celebrated a minor milestone for mileage recently:
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3399
Had the oil pump seal replaced soon after purchase when I had the aux belt and tensioner changed. All these jobs need the fan and cowl removing for access which is time consuming but it shouldn't need the engine out. If the Aux belt is oil contaminated it will squeal on cold starts in the morning and may well struggle to drive the alternator, AC compressor etc so I would get it sorted. Rear toe adjusters seizing is also common but was the alignment within tolerance? Just goes to show that even low mileage late L322's will cost you ££ as parts deteriorate with age and corrosion irrespective of mileage. 2012 TDV8 Vogue (L322) |
| Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 308
Yes! ( unfortunately): there are two common issues: 1.) the oil pump nut gallery 2.) the oil seal on the oil pump drive. 1) There is an LR technical service bulletin for the TDV8 4.4 on this. GlenRands advised me it was the smaller of the two jobs at 3 to 4 hours Labour. 2.) This needs removal/replace of the oil pump and specialist LR tools to accurately position the new seal in the engine block. GlenRands advised this can be done with engine in situ but it’s 18 hours Labour. I have issue number 2.) I’ve had my car just over a year now…. Love it to bits! BUT with this job, the suspension refurb and various other upgrades I’ve chosen to have done I’ve probably spent upwards of £7.5k maintaining it! TDV8 4.4 2012 Last edited by Ramblin Man on 12th Nov 2023 9:34pm. Edited 1 time in total |
Well, having followed the Tom Lenthall "drive it and monitor" route since it was last serviced in February it started 'marking its territory' this week. I've finally followed your advice and she's booked in with Glenrands at the beginning of next month. I'm hoping they know you're called DrRob on here because that's who I told them sent me! 2012 L322 TDV8 Vogue SE: Buckingham Blue 2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten |
They do |
Oil pump leaks. Usually it’s from a hex bolt and is not a massive job. Fix is remove bolt, add sealant, refit. Again, depends on where the weep is from. Glenrands will review and advise |
Very disappointing update, Glenrands suggest it’s the oil cooler and that to remedy will be 10 hours Labour plus parts… I paid my £72 diagnostic charge and took it back to Tom Lenthall because the oil cooler is a new Land Rover part fitted last February so still within its two year warranty.
I’ve made Ross at Glenrands aware of the above as I suspect the 10 hours was to cover additional leaks or issues they found on your vehicle inspection. They go through everything thoroughly I can assure you |
Hi DrRob - and others reading this.
| All times are GMT |
