![]() | Home > In Car Electronics (L405) > USB not recognising iPhone (or anything!) |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1778 ![]() ![]() ![]() |
Everything works fine all the time in my MY2017 L405.
DamianK Member Since: 04 Aug 2023 Location: West Sussex Posts: 58 ![]() ![]() |
Thank you for the reply.
I can’t imagine it needs coding to the car, but perhaps someone more knowledgeable than me like Phoenix can advise. Still not a cheap fix at £75-£100 used, so I’d wait for a bit more feedback here before you commit to it, there may be other advice, I’m no expert on this subject, just trying to help. V6 Vogue - “Less is More” - less to go wrong! |
I hear you and I appreciate your input. |
It should just connect & work - it's just an interface / media converter.
Thanks - I can see a new one for sale on ebay but I am a little unsure on how easy it is to remove the old one and replace with the new one - the unit feels like it would just pull out but I am assuming there is going to more to it than that.
Thanks Phoenix.
It does just clip in - but - the harness doesn't have any slack in it to allow full access to the connectors, so you need to remove a few bits, about 20 mins from memory but it's been a few years since I changed one.
Thanks
Hi Damian, this is what I had seen before, not identical but may give you some insight:
Hi - sorry for being stupid but what did you mean by this? have a look under body & paint for 'Floor console upper section R&I' that will get you access to the connectors. |
In the Workshop Manual - downloadable from the 'Wiki' link on the top right of the home webpage.
He means in the WM (Workshop Manual) in the Wiki above.
Funny echo in here today, |
