Home > Technical (L322) > Nobody knows what is going on with my 4.4 TDV8 2011...
Page 2 of 3 <123>
JayGee
The throttle plate is used to create negative pressure in the intake to increase EGR flow if the system senses this is low. Who did the remap and EGR delete? Many firms offer this but not all can actually do it properly. 2012 TDV8 Vogue (L322)
Post #676850 30th Oct 2023 3:08pm
Yorch1
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Java Black
Was done by Glenside Motors, part of Quantum, in Linconshire
Post #676853 30th Oct 2023 3:29pm
johnboyairey
my 2p..... has the noise been proved to the throttle flap on top of engine? or is the turbo intercooler flap valve at bottom of the radiator doing it? is it thinking it needs to release stored cooled air at pressure to 'blow-off' ie to stop the engine.?
Post #676861 30th Oct 2023 5:35pm
GraemeS
Australia
With EGR mapped out that throttle plate should be horizontal. Either the remap has been removed at a dealer service or the throttle mechanism is broken. However if the remap has been removed yet the blanking plate remains fitted then the engine would try to stall whenever not on the throttle and you wouldn't be worrying about just a sucking noise as the vehicle would be basically undriveable.
Post #676871 30th Oct 2023 8:39pm
garyRR
I too am thinking about the remap / EGR delete. The 4.4 TDV8 typially has well documented issues and what you describe doesn't seem to match experience of others.
If the EGR is blanked but the PCM is sending commands and not getting a relative position back, it will adjust commands else where and explain your symptoms. 2015 Range Rover Autobiography 4.4 SDV8
Post #676877 30th Oct 2023 10:41pm
cass
What problems were you trying to fix when you had the remap/EGR removal?
Many will disagree but I would always undo any improvements/mods before trying to find a fault, you could be chasing your tail forever without a solid place to start.
Post #676923 31st Oct 2023 2:50pm
Yorch1
Fellas, first of all THANK YOU TO EVERYONE for trying to help.
That clicking noise is coming from the butterfly valve at top front of the plenum. That clicking noise is the valve opening and closing.
EGR is blanked with a blanking plate so...should that butterfly valve be open always and not moving from that position???
I suspect that the remapping was not done properly.
The question now is: to prove it is the mapping, where can I go in Peterborough for a new remap properly done?
Post #676937 31st Oct 2023 6:54pm
garyRR
It should perform a cycle at ignition off.
It shouldn't ever be flapping wide open and closed. The PCM should be commanding the actuator to open to a precise level. 2015 Range Rover Autobiography 4.4 SDV8
Post #676939 31st Oct 2023 6:57pm
JayGee
Do yourself a favour and remove the plastic connector to the throttle - see this guide
https://www.fullfatrr.com/forum/topic48780.html
and see if the plate is loose. 2012 TDV8 Vogue (L322)
Post #676944 31st Oct 2023 8:47pm
GraemeS
Australia
No, the butterfly is spring-loaded to the open position so should be open with the ignition off.
As I stated above, with EGR mapped-out the butterfly should always be open while the engine is switched on. Hence if it isn't fully open with the ignition on then either the remap has been removed or the butterfly drive mechanism has stripped its gears.
Post #676945 31st Oct 2023 8:50pm
Phoenix
Or the shaft seal has failed and there is oil ingress into the electronics for the position sensor...
Like this (Non-JLR) one.
Post #676950 31st Oct 2023 9:24pm
General
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Mine was making the same noise and I replaced the throttle body,it has been spot on for nearly 2000 miles since.
Part no was,LR020694
Post #676953 31st Oct 2023 10:07pm
rjff
Here you go Phoenix
From mine:
Butterfly become well fouled and finally sheared the drive gears. Cheers
Richard
Gap IIDBT
Post #676974 1st Nov 2023 9:52am
Yorch1
Well...I had an EGR problem with restricted performance. I decided to blank it to save some money but so far I have spent much much more. I really regret it.
Post #676985 1st Nov 2023 12:08pm
Yorch1
Is your EGR blanked?
Post #676986 1st Nov 2023 12:10pm
Page 2 of 3 <123>
