![]() | Home > Technical (L322) > Do (2008) 3.6's suffer from spline wear in the drive train ? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2767 ![]() ![]() |
Yes, spline wear on the gearbox o/p shaft and the transfer case input shaft is a known issue and will eventually strip both shafts. They're assembled with a special grease but either the quantity of grease applied at assembly is sometimes inadequate or on some the grease dries more quickly than on others.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 189 ![]() ![]() ![]() |
Oh balls ! Not looking forward to removing the t-box. Not looking forward to fixing the problem either ! |
Obviously you need to eliminate all other possibilities first. |
Yes I need to spend some time under the thing anyway. I discovered a small oil drip where the rear of the lower front a-arm is attached to the engine cradle thing and I need to change the oils as well. |
