![]() | Home > Maintenance & Mods (L405) > Trickl charging battery |
Plumbman Member Since: 29 Nov 2023 Location: Rochdale Posts: 4 ![]() ![]() ![]() |
Can you use a trickle charger on a landrover L405 |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1170 ![]() ![]() ![]() |
Mine is on one 24/7 connected to the terminals under the bonnet. overfinch modified |
Thanks for the reply, Any issues and how long have you used this? JD |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1424 ![]() ![]() ![]() |
If you have towing electrics one can get adaptors that plug the trickle charger in there which is the most convenient method as far as I am concerned. Only Range Rovers since 1988 |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
This charger:
Thanks for the prompt and useful replies, what’s AGM battery .? By the way. Cheers. J D |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 193 ![]() ![]() ![]() |
What is the reason for not using “recond” with the AGM battery? |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2622 ![]() ![]() |
It won’t help anything because the Recond mode is designed to mix up the separated acid and water in flooded batteries, and AGM batteries aren’t flooded, so that separation doesn’t happen:
AGM = “Absorbent Glass Mat”
Many thanks gremlin and to the others who took the trouble to reply. J D |
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Any thoughts on the CTEK CS FREE booster?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
Do you have a very long extension lead for when you do go out....??? Sorry couldn't resist.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
AnnualMan Member Since: 16 Apr 2023 Location: Zurich Posts: 188 ![]() ![]() |
I’ve had the CS Free for a few year now and I can tell you it’s pretty disappointing. I thought it was the solution to keeping my BMW X1 12v topped up without the need for an electricity socket in the garage. The reality was despite the cars battery being in decent nick, the CS Free would drain its battery to empty in under 24hrs.
(AM)
