Home > Technical (L322) > Dunlop air bags - knocking
Slow progress
Hi All,
Can anyone help me, I had a pair of Dunlop air struts fitted earlier in the year and they appear to be the source of an irritating knocking sound. The airbags work and don’t leak, but are making a low speed knocking noise.
Does anyone know the root cause for the Dunlop ones? Is there a fix? Or is the only solution to source Delphi ones?
Many thanks,
David L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #678523 22nd Nov 2023 7:37pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Are you sure it's not the drop links? They are rather inexpensive and easy to replace. Also, I think there should be a warranty on the struts should they turn out to be the culprit.
Post #679236 1st Dec 2023 5:52pm
Merchy
Same thoughts as in the above post, plus it may be that whoever fitted the new parts made a mistake when working on the car ? If both are causing the knocking sound then I rather doubt that the parts are faulty, a quick MOT style inspection whilst the car is up on a lift could reveal where the problem is.
Post #679240 1st Dec 2023 6:37pm
JayGee
You had the complete stut and not just the airbag replaced? If so shocks can knock and have had this on other cars. 2012 TDV8 Vogue (L322)
Post #679246 1st Dec 2023 7:57pm
Slow progress
Both have been changed, droplinks were the first port of call, no improvement. The knocking has only started since the struts were changed. We’ve tried it on the shaker table, and it sounds like the struts but both have been replaced in the past 12 months….however found this article and it feels the same position;
https://www.rangerovers.net/threads/l322-f...ed.223954/ L322 TD6 2003
Post #679287 2nd Dec 2023 11:18am
vs322
I did have a Dunlop front strut that was knocking. Replaced both with Arnott, which in turn, after 60K km seem to knock slightly when the weather is cold for the first couple kilometers of the day...Nothing as bad as the Dunlop though and definitely something I can live with.
Post #679308 2nd Dec 2023 7:11pm
Slow progress
That’s helpful, not sure if you can still get the Delphi ones so they’d be a good back up L322 TD6 2003
Post #679311 2nd Dec 2023 8:32pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Delphi brake and suspension units, designs, intellectual rights and production lines were bought out by BWI in 2010. 'Delphi' suspenion units are still made but under BWI name.
Post #679319 2nd Dec 2023 10:47pm
