Home > Maintenance & Mods (L322) > Oil service reset
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Oil service reset
Hi
Just done my first oil service and can’t reset the service warning.
Tried the bonnet open, door open, hold button thing… doesn’t work.
2008 3.6 TDV8. How do I do it please, do I have to use my gap tool? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #679393 4th Dec 2023 12:10am
garyRR
Manual Reset Procedure 2006-2009:
All doors, boot, windows and bonnet to be closed.
Press and hold the trip reset button, the button on the left of the instrument cluster.
Turn the ignition switch on to the ignition position two, don't start the car.
If the Service Indicator Interval function is entered the cluster will say 'SERVICE’ for five seconds and then display ‘SERVICE’ constantly. If the Service Indicator Interval function is not enabled the information display will show your mileage.
If the trip reset button is released within ten seconds of entering the reset mode, the information display will show ‘DIST’. If the trip reset button is not released after ten seconds the instrument cluster will exit the manual reset procedure.
If you want to reset the service, press the button on the left of the cluster within ten seconds for five seconds.
...it's also very easy to do in the GAP tool. 2015 Range Rover Autobiography 4.4 SDV8
Post #679400 4th Dec 2023 3:38am
DrRob
If you have a GAP IID then simply plug in and use that. It's under "Service" IIRC Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #679405 4th Dec 2023 8:30am
tymh
This may be where I went wrong as the YT video I say said bonnet and door OPEN...
Might have to resort to this if the other doesn't work Wink Tym
Post #679412 4th Dec 2023 1:14pm
tymh
Thanks Tym
Post #679413 4th Dec 2023 1:14pm
To be fair, I always thought you needed the bonnet & Drivers door open... Whistle Thumbs Up
Post #679420 4th Dec 2023 2:33pm
tymh
tymh wrote:
Thanks
I ended up using IID. All done. Tym
Post #679496 4th Dec 2023 11:46pm
