|  | Home > Technical (L322) > 6HP28 Possibly Juddering |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | I think the EDS2 solenoid current would be useful as an additional measurement (albeit at the cost of a reduction in sampling frequency) so that we can see what the torque converter lock-up clutch is being told to do (i.e. off, controlled slip or locked solid)
|  3rd Dec 2023 9:13pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Thanks Phil,
|  3rd Dec 2023 9:31pm |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | At road speeds such as 65mph & 80mph you’d clearly expect the lock-up clutch to be fully engaged (i.e. locked solid) and therefore the engine and turbine speeds would be identical. As they aren’t, this would appear to be a LUC issue.
|  3rd Dec 2023 10:38pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Thanks Phil, your input is massively appreciated. I’ve been chasing my tail thinking this was an engine fault after I’d done the timing chains and not getting anywhere with it.
|  3rd Dec 2023 11:03pm |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | Gentle acceleration up through the gears would show the point at which the LUC is applied and then the transition from controlled slip mode to fully-engaged.
|  3rd Dec 2023 11:47pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | My IID tool isn’t doing anything with the solenoids unfortunately despite changing the firmware as suggested by Patrick  | ||||||||||
|  4th Dec 2023 9:09pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | This is the whole list is what can be monitored from the Transmission ECU using SDD.
|  4th Dec 2023 9:26pm |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | That’s very disappointing. So it isn’t looking like we’ll get to the solution through diagnostics, and replacing the torque converter is obviously a big job. I just wondered if it might be worth replacing EDS2 first, on the off-chance that it’s a solenoid fault causing the issue, before resorting to major surgery?
|  5th Dec 2023 10:44am |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | I was beginning to wonder the same thing if I’m honest.
|  5th Dec 2023 10:50am |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | The yellow cap & blue cap solenoids from the 6HP26 are the same parts used for the 6HP28, but the 6HP26 didn’t use the orange cap solenoids. The function of the orange cap solenoids is the same as the yellow cap (i.e. increasing pressure with increasing current), but the inlet and outlet ports are reversed, so they aren’t interchangeable.
|  5th Dec 2023 11:08am |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Thanks Phil, I didn’t remember seeing the orange cap ones which now makes sense!
|  5th Dec 2023 2:10pm |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | Although I can see why it would be tempting to change as many of the solenoids as possible while you’re at it, especially if you have much newer ones lying around, I’d be concerned that this may lead to further complications as all the pressure & time adaptions would initially change and the controller would be trying to adjust the shift times for all the clutches at once. If you possibly can, I would just try to stick with the single solenoid change (EDS2) so that we can immediately see if it has any effect.
|  5th Dec 2023 6:19pm |
| pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 36      | Hi guys,
|  5th Dec 2023 6:37pm |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3349      | Thanks Phil, PM incoming  | ||
|  5th Dec 2023 8:05pm |
| Posting Rules
