Home > Technical (L322) > 6HP28 Possibly Juddering
Page 4 of 4 <1234
RobWCanada
Canada 2011 Range Rover Autobiography 5.0 SC V8 Ipanema Sand
Niiiice! Thanks David! With your description I was able to figure it out! Too bad GAP doesn’t have an option to lock axis cause it’s still kinda fiddly.
Anyway for anyone wondering the same thing:
- once you tap either of the axis on the left or tap the bottom left description (engine speed, turbine speed) — tapping these cycles graph selection
- the graph will then be bold, to up/down on the vertical axis just slide up and down
- to change axis scale (rpm scaling in this case) pinch and zoom VERTICALLY
- if you want to change the time scale pinch and zoom horizontally
So, with that said, looking at my transmission graph for 39 seconds, I believe my solenoids are fine, what say you? @dhallworth and @rrphil
Transmission engine speed kinda steps but I see that in David’s graph too, so maybe it just doesn’t report as often?
R 2011 Range Rover L322 SC - Autobiography (Ipanema Sand)
Ontario, Canada
Post #716993 28th Apr 2025 3:19pm
RobWCanada
Just another example. While starting around 20km/hr
…if I don’t need to replace the solenoids at least this great thread has allowed me to see that I can no doubt do the transmission fluid flush & fill Smile
Ontario, Canada
Post #716995 28th Apr 2025 3:23pm
sthamwich
Hey David, I just wanted to extend my thanks to posting and documenting your issue as Ive been encountering the same juddering/jerking under light acceleration during highway speeds which has been intermittent over the course of 2-3 years. Lately its been occurring more frequently. Its extremely random too, I can restart the engine and it goes away. 2011 Range Rover Sport 5.0 SC.
Ive replaced the injectors on the car (during the timing chain replacement), and installed brand new MAFs. Ive smoked tested the engine in various places and addressed all intake track leaks.
After reading this thread Ive ordered a new set of solenoids, dampers, sandwich plate, seal kit and Metal Pan (I have an L320, so installing OE pan is pain!)
Like you I do not want to replace the TC as everyone seems to blame that once juddering/shuddering occurs.
Im cautiously optimistic the new solenoids and dampers will cure this problem.!
Thanks to RRPhil for his expert within this thread as well.
Post #722032 29th Jul 2025 2:13pm
Phil02880
France
I've been following this thread with great interest.
Thanks to RRPhil for his expertise!
I'd like to talk to you about my problem with my ZF6HP26, but it's an Aston Martin...
Post #723619 29th Aug 2025 8:00pm
RRPhil
Ooooh, I’m very keen on the Aston Martin Touchtronic II transmission, in fact I have three on my workbench at the moment. One is a 037 unit (4G4370041AF) from a 2006 DB9, the second is a 084 model (8G4370041AB) from a 2008 DB9 and the third is a 097 unit (CD3370041AA) from a 2013 Rapide. Gorgeous!
The Graziano final drive is rather fabulous, too, with its amboid crown wheel & pinion setup!
I’m sure if your questions were relevant to the Range Rover transmission, too, we’d get away with it?
Phil
Post #723665 30th Aug 2025 6:01pm
Phil02880
France
Thank you very much RRPhil
I will try to write a precise message.
can I put it here, or on the general forum in "off-topic other cars"?
that the whole community benefitsthe 6HP26 issues ?
Phil
Post #723835 2nd Sep 2025 8:53pm
RRPhil
I'll try sending you a PM and we can see if you're able to respond.
Phil
Post #723840 2nd Sep 2025 10:17pm
Cr8r78
United States 2016 Range Rover 5.0 SC V8 Loire Blue
Re: 6HP28 Possibly Juddering
Dhallworth, et al… what a great thread with so much good data.
For a novice trying to learn how to do this all myself, would you now suggest:
Step 1: change trans filter and fluid
If symptoms remain,
Step 2: change trans filter and fluid
If symptoms remain,
Step 3: change the solenoids
If symptoms remain,
Step 4: change TC
If symptoms remain,
Step 5: change transmission
[quote="dhallworth"]I’ve been trying to diagnose what I thought was a hesitation from the engine on my 5.0 L322, however the more I’m looking at it I cannot find anything wrong with the engine. It’s logging zero misfires of any kind and there’s nothing jumping out that would be causing any problems.
Post #725732 7th Oct 2025 4:27am
Page 4 of 4 <1234
