![]() | Home > Maintenance & Mods (L405) > Front Brake Pads - Tools & Parts |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
I had mine out the other day pins and fixings were fine and the sensor lead was also all okay so I did not replace them just cleaned them and greased them. Just punch, socket set and some pliers, brake cleaner. overfinch modified |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 497 ![]() ![]() ![]() |
This is the project next week. I am hoping the weather improves. Why is it always winter when I need to work on the RR? SDV8 AB MY 2020
Going well and then this pin is stuck…
A good soaking with plus gas and then a light hammer on the punch to get it moving, keep spraying it .
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
I recently had to cut the bottom ones on both sides and then the last bit came out with a long punch. letters not necessarily in the right order |
Hey Lux how many miles has the car done ? Those discs look like they need changing also, must be all that Autobahn use. |
70,000 km.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1698 ![]() ![]() ![]() |
Pin on the Right looks to be the correct one to me, the smaller diameter in the centre section locates the leaf spring. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
The thicker one are the one from the factory or were on the car from new.
You will need a large torx bit to undo the calliper and a big torque wrench to do it back up. There is a good YouTube video. letters not necessarily in the right order |
The calliper bolts that are tight are 21mm bolts. Once again they need a good spray and a nice long bar to remove them. overfinch modified |
New discs, wear sensor & a rebuild kit ordered.
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 912 ![]() ![]() ![]() |
High risk of melting the piston seals / dust covers before the caliper releases its grip on the pin.
