Home > Maintenance & Mods (L405) > Front end clunk I’m lost
sconnell80
United States 2016 Range Rover 5.0 SC V8 Corris Grey
Have a 2016 L405 that I have replaced all 4 lower control arms, sway bar bushings and sway bar links to battle front end clunking. Well it’s definitely a lot tighter up front and smoother ride but some smaller bumps where the suspension side to side I’m still getting a clunk. It’s more of like a metal on metal rattle but when I check underneath the rover with a dead blow against all parts I get nothing. I’m stumped. I’d really hate to replace both front air shocks for nothing as they are pricey. Has anybody else found any issues other than the usual parts that I’ve already changed? Thanks in advance.
Post #679587 6th Dec 2023 1:27am
A couple of possible leads -
https://www.fullfatrr.com/forum/topic59269.html
https://www.fullfatrr.com/forum/topic54180.html
Post #679597 6th Dec 2023 8:11am
dingg1
Track rod ends been changed?
Post #679604 6th Dec 2023 11:17am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Possibly contamination between the ARB and bushes as per LTB00720v7?
https://www.fullfatrr.com/gallery/displayi...&pos=0 L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #679637 6th Dec 2023 5:37pm
sconnell80
Sway bar was nice and clean still black and smooth
Post #679640 6th Dec 2023 5:53pm
dingg1
https://bookmygarage.com/blog/track-rod-end-need-to-knows/
Post #679653 6th Dec 2023 8:19pm
sconnell80
None of those symptoms and I had a buddy move the wheel left to right and I watched movement of tie rod ends.
Post #679655 6th Dec 2023 8:38pm
Phoenix
Post #679657 6th Dec 2023 8:50pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
If it's only related to one sided bumps, i.e. if both wheels on the same axle traversing the same bump together it doesn't happen then you're most likely to have issues with the ARB.
Either the bushes themselves, the mountings or more likely the drop links.
I'd run round all the mounting points making sure they're torqued up correctly.
If you're getting a shimmy when you're going over bumps then I'd say you have a dodgy shock.
Cheers
Post #679659 6th Dec 2023 8:57pm
sconnell80
New nuts with the new drop links, all chassis bolts were torqued down while on the ground and the strut wishbone as well. Sway bar was clean and smooth before putting in new bushings with opening facing rear of vehicle then clamshell torqued to sway bar brackets then sway bar brackets torqued to chassis. Didn’t see any leaks from the hoses or motor on sway bar.inner tie rods and outer tie rods feel good and I checked everything possible with a dead blow for noise and got nothing. The noise is definitely up front on both sides. Hit a bump in the road with both wheels at same time no noise, one side or the other and it’s like a clunk/rattle. Anytime after be side or the other is off level with the other side I get the clunk. You don’t feel the clunk in the steering wheel or in the floorboards/seat. Had a buddy ride with me and we both work on cars for hobby and just scratching our heads. Reading online I see issues with the sway bar design. I’m almost contemplating changing air struts as they have 82K on them and the vehicle is a tank. I’m still learning everything about this thing so not sure if I have active or passive arb but it has hydraulic hoses going to the pump/motor on the sway bar
Post #679662 6th Dec 2023 9:31pm
sconnell80
AndyRoo wrote:
Hi,
Cheers
Definitely one side or the other up front, hit the bump with both front wheels it’s good. New bushings and sway bar links installed when I did all 4 lower control arms.
Post #679663 6th Dec 2023 9:33pm
Phoenix
Post #679664 6th Dec 2023 9:44pm
sconnell80
I have not tried bleeding the system yet but I will check out the manual and see if I can get it done. I’ve already got one car in the shop under warranty I don’t wanna have 2 but if it comes down to it I’ll let the dealership figure it out after that.
Post #679665 6th Dec 2023 9:49pm
sconnell80
Unfortunately I don’t have a way to pressurize the reservoir so I can bleed both sides like manual says
Post #679666 6th Dec 2023 10:05pm
Phoenix
Post #679668 6th Dec 2023 10:30pm
