Home > Maintenance & Mods (L322) > Ride Height Sensor bracket
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
I have a fault with my front drivers ride height sensor and ordered a replacement which arrived, but ordered one without the mounting bracket (foolish I know) and the Torx screws are very soft and shredding, so they aren't going anywhere!
So long story short, where can I get the replacement brackets from that is not going to be £236 from a dealer and will the older style fit as they seem to under a tenner each!
Many thanks in advance Confused 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #679804 8th Dec 2023 4:02pm
mjdronfield
Older style bracket should fit. I ended up cutting the old height sensor away so I could grip the bolts and the captive end that was spinning. I then used a normal bolt to attach the new height sensor.
Was a right pain.
Didn’t realise you could get the bracket elsewhere…. I too got a daft price from the dealer for one.
I think there are some non OE height sensors that come with the bracket.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #679814 8th Dec 2023 5:47pm
Paul H
aye was so frustrating that it was such an easy job to get it off and I was screwed by a 79p bolt that shredded!
Good idea on cutting the old sensor apart that may actually be easier than drilling out the bolt heads Razz 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #679815 8th Dec 2023 5:56pm
mjdronfield
I used some hefty wire cutters on the black plastic. Then ended up using pliers on each end. There is a round collar that’s threaded and it just spins in the plastic.
I can’t remember what size the bolt was that I threaded into the new sensor.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #679816 8th Dec 2023 6:10pm
Merchy
As above, there are plenty of non OEM height sensors complete with bracket for peanuts on the net, cheap way of getting a new bracket, then you have a spare sensor for emergency fitting. It seems that the bracket alone from LR is around £50 to 60 Censored
Post #679833 8th Dec 2023 9:17pm
mjdronfield
The bracket alone is over £200….. if I remember my quote right….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #679837 8th Dec 2023 10:21pm
mjdronfield
Just looked at my old thread… seems it was £170 odd for the bracket. More than the OE height sensor….
https://www.fullfatrr.com/forum/topic55316.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #679838 8th Dec 2023 10:31pm
Paul H
Unfortunately the 2010/2011 has the six pin not three pin sensor, managed to get the sensor pretty cheap £50 but trying to find a seperate bracket was a nightmare for a 6 pin with bracket. Going with the hack and pray method or will buy a cheap 3 pin with bracket and use that as can’t find the bracket alone for under £200 for a piece of bent metal!
Pre 2010 the bracket is less than a tenner!!! 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #679854 9th Dec 2023 7:26am
mjdronfield
We meant just get a 3 pin non OE just for the bracket…. Assume brackets are the same….. can’t see why not…. Where are the brackets for less than a tenner? Might be useful for future.
I’d hack the old sensor off and use existing bracket.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #679868 9th Dec 2023 12:07pm
Paul H
the old pre 2010 brackets are these https://www.lrparts.net/rqu000200-bracket-...-2009.html
The 2010 onwards are the same for both 3pin and 6pin but are a different part number from the pre 2009 Crying or Very sad
Just in the process of dremeling off the old bolts! 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #679869 9th Dec 2023 12:12pm
