Home > Maintenance & Mods (L322) > Ride Height Sensor bracket |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7649 |
Older style bracket should fit. I ended up cutting the old height sensor away so I could grip the bolts and the captive end that was spinning. I then used a normal bolt to attach the new height sensor.
8th Dec 2023 5:47pm |
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 40 |
aye was so frustrating that it was such an easy job to get it off and I was screwed by a 79p bolt that shredded!
8th Dec 2023 5:56pm |
I used some hefty wire cutters on the black plastic. Then ended up using pliers on each end. There is a round collar that’s threaded and it just spins in the plastic.
8th Dec 2023 6:10pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
As above, there are plenty of non OEM height sensors complete with bracket for peanuts on the net, cheap way of getting a new bracket, then you have a spare sensor for emergency fitting. It seems that the bracket alone from LR is around £50 to 60 |
8th Dec 2023 9:17pm |
The bracket alone is over £200….. if I remember my quote right….
8th Dec 2023 10:21pm |
Just looked at my old thread… seems it was £170 odd for the bracket. More than the OE height sensor….
8th Dec 2023 10:31pm |
Unfortunately the 2010/2011 has the six pin not three pin sensor, managed to get the sensor pretty cheap £50 but trying to find a seperate bracket was a nightmare for a 6 pin with bracket. Going with the hack and pray method or will buy a cheap 3 pin with bracket and use that as can’t find the bracket alone for under £200 for a piece of bent metal! Pre 2010 the bracket is less than a tenner!!! 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
9th Dec 2023 7:26am |
We meant just get a 3 pin non OE just for the bracket…. Assume brackets are the same….. can’t see why not…. Where are the brackets for less than a tenner? Might be useful for future.
9th Dec 2023 12:07pm |
the old pre 2010 brackets are these https://www.lrparts.net/rqu000200-bracket-...-2009.html
9th Dec 2023 12:12pm |
