![]() | Home > Maintenance & Mods (L405) > fitting roof rails / ditch fillers |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818 ![]() ![]() |
Done this - yes they can - no issues whatsoever 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1096 ![]() ![]() ![]() |
Had rails fitted by the dealer and never taken them off, I actually like the look. Cross bars are fitted when needed. Given the ditch fillers are plastic, they are bound to break with regular removal/fitting, so I’d leave the rails in situ. |
mkacala Member Since: 22 Nov 2023 Location: Bucks Posts: 31 ![]() ![]() ![]() |
thankyou guys much appreciated.... are the ditch fillers plastic ? I thought they were aluminium (painted either silver of black ?) |
I'm not sure if they are noisy ... although I would guess the bars are noisy ? Well I have no choice so will fit the rails and bars and let everyone know how it works out ! |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303 ![]() ![]() ![]() |
Came here to write the same. I drilled mine as per the Powerful UK kit. FWIW by the way, I wouldn't recommend the Powerful UK kit, it is poorly fitting, the plastic trims are very brittle and the supplied fixings are as soft as cheese. IMHO. The only noise I got is because the right-hand rail doesn't fit flush enough with the roof. I've had to in-fill it slightly with some tap to stop it whistling. Once done, there is no additional noise from the rails themselves. If I had my time again I'd stretch for OEM rails. FFRR SDV8 Autobiography |
No noise from the rails, even at motorway speeds. Put the cross bars on and there is a noticeable change in noise, but not excessively so. |
