Home > Maintenance & Mods (L322) > Bevinsee H7
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Bevinsee H7
Anybody upgraded their full beam to Bevinsee bulbs? Bought them but can’t get them to fit in my 07 SE! I could be missing a clip to hold the bulb in place, but saying that, my fingers are not that long to push the bulb home! My H7 has the long plastic adapter to place the bulb!!
Bulbs in question are V55 H7 LED,
Think they probably fit the face lift model…………………..
David 2014 vogue se
Post #660182 23rd Mar 2023 10:29pm
KF
Finland 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi, I did just that couple of weeks ago, -07 TDV8, there´s a metal plate that locks the original bulb in place that you need to modify. I took some metal of with dremel so that the plate can be installed between the Bevinsee ring and chassis.
Take the plastic stick away as you can´t use it and connect the Bevinsee connector directly to the connector that´s at the end of the plastic stick.
Otherwise quite straightforward, just need some filling for the electronic box that it doesn´t rattle around the headlight. -07 Stornoway Gray TDV8
Post #660203 24th Mar 2023 9:07am
DrRob
Straight fit on my 2011 so I guess there's some slight differences....although my LED bulb does sit at a slight angle off vertical. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #660214 24th Mar 2023 10:36am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
V45 series bulbs (H7 LEDs) is what i used
Really easy fitting
Not sure about the V55
Post #660310 25th Mar 2023 9:55am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
What did everyone do with the dongle/ballast thing attached to them?
Did you secure it inside the headlamp or leave it outside?
A it has a kind of heatsink I wondered if it was heat sensitive and was better off in the engine bay... If inside, how to fix it? Wonder if it'll survive bouncing around or worse, will it damage the wiring inside the headlight...
Post #680077 11th Dec 2023 10:17pm
DrRob
As per Sam's video = push inside and screw the cap back on Whistle Thumbs Up
If you don't know who I'm on about then look for Sams Motors and Machines channel on YouTube Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #680103 12th Dec 2023 9:11am
Siftah
Ah, yeah, I found the video now, couldn't see it last night when I looked! Smile
I'm not convinced it's great to leave them just flopping about tbh, I think I'll add a patch of 3m VHB and stick them down!
Post #680115 12th Dec 2023 11:09am
