Home > Maintenance & Mods (L405) > Headlight removal to change headlight bulb?
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys I cannot how much of a pain in the ass it is just to change a headlight bulb on these vehicles I have managed to change the passenger side by removing air box but driver side is a nightmare not enough clearance to remove the air box etc… Is there an easier way any tips or is it a height off job which involves the bumper removal I believe.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #681215 26th Dec 2023 6:38pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi Jay, no its still an airbox out job for the o/s, just unscrew the top and unscrew jubilee clip for adjoining hose, there’s also a small vacuum hose on the side to pull out and unclip the wire for the airflow sensor then it just lifts out. Also if you pull the rubber seal off just behind it gives a bit more room as you lift it out.
Post #681224 26th Dec 2023 9:14pm
As Dave says above, its very easy... 10mins a side... Thumbs Up
Post #681277 28th Dec 2023 1:11am
