![]() | Home > Maintenance & Mods (L405) > Headlight removal to change headlight bulb? |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Hi Jay, no its still an airbox out job for the o/s, just unscrew the top and unscrew jubilee clip for adjoining hose, there’s also a small vacuum hose on the side to pull out and unclip the wire for the airflow sensor then it just lifts out. Also if you pull the rubber seal off just behind it gives a bit more room as you lift it out. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
As Dave says above, its very easy... 10mins a side... |
