Home > Technical (L405) > Battery replacement
V8Russ
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Battery replacement
I recently had a full JLR health check and the only issue found was I needed a new battery.
I've not had any issues other than the odd "Battery Low Start Engine" or "System Shutting Down".
But I assume thats as I had the radio on for a while.
Sometimes I also get a clicking sound from the off side rear battery area when ignition is turned off.
Anyway, which battery should I buy? AGM or Lead Acid?
Would I have to change both batteries?
Which AGM below would you recommend?
Halfords AGM 019 £246 + £28 fitting.
Europarts, Exide £304
Tayna, Enduroline £200 (they state a 020 not 019?)
Kwik Fit, Bosch £243
GSF, Yuasa £172
Post #681249 27th Dec 2023 5:01pm
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
I bought a EK950 Exide Start-Stop AGM Car Battery 95Ah 017 from tayna. Same size and CCA as the OEM one and slightly more amp hour. Exide made my original battery so I thought it was the best option as the local dealer had them on back order for trade.
I had to reset the BMS with pathfinder but after that it's stopped complaining about the low battery. Some garages will have a tool that can do the reset but I'm not convinced Halfords will so double check.
If you have a 2017 you will only have the main battery.
Also worth noting a genuine jlr battery is similar to some of those prices you've put up so you could just take it to the dealership.
Post #681273 27th Dec 2023 11:02pm
Gremlin500
I got the Enduroline AGM for my 2017, because it had the 5-year warranty.
Only 18mths in, seems to be OK. V6 Vogue - “Less is More” - less to go wrong!
Post #681275 28th Dec 2023 12:03am
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Maltings off road have a genuine battery for sale for what seems a very reasonable price.239.99 2016 4.4 diesel
Post #681294 28th Dec 2023 9:41am
V8Russ
Thanks guys.
Looks like the Halfords is the middle of the road and a 5 year warranty.
What do you think about buying the accessory battery, do they fail as much as the main?
Post #681302 28th Dec 2023 12:13pm
V8Russ
FYI. Went for the GSF battery for £170 and 4 year warranty. Ill fit it tomorrow.
I couldn't find how to access the aux battery, if it has one?
Post #681335 28th Dec 2023 5:18pm
as you stand looking into the load area ,the panel on the right [drivers side] houses the battery or a capacitor ... ... - .- -.
Post #681336 28th Dec 2023 5:28pm
V8Russ
No panel. Ive pulled and tugged at the vent on rear drivers side boot liner thinking a panel will dislodge but nothing.
Post #681338 28th Dec 2023 5:33pm
start pulling by the rear seats.. ... - .- -.
Post #681345 28th Dec 2023 6:54pm
There's a built in handle to pull on... Near the buttons for the seats...
If it were me, I would pay the extra and buy genuine JLR batteries... Thumbs Up
Post #681361 28th Dec 2023 9:12pm
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
JLR manufacture their own batteries?
Post #681396 29th Dec 2023 12:29pm
dont think they make them but they certainly sell them.. ... - .- -.
Post #681398 29th Dec 2023 12:38pm
No sir of course they don’t manufacture there out batteries! Nor do they manufacture tyres sir 🛞🛞🛞… Whistle Rolling Eyes Whistle
As Stan says, they do sell them! And they are made to very fine tolerances so won’t be copied or beaten by other manufacturers in terms of quality or materials used… for sure… Thumbs Up
Post #681404 29th Dec 2023 1:38pm
caymanblack
How much is the JLR battery from the MD though?
One bought from Tanya say like Gremlins still has the 5 year warranty some JLR ones might not last that so for items like that, i dont believe its worth it.
As for tyres I see mine once had some fitted and bought from the MDs and the price was good! overfinch modified
Post #681406 29th Dec 2023 2:32pm
Tanya batteries lol love that… Rolling with laughter Laughing Bow down Thumbs Up
Post #681408 29th Dec 2023 4:09pm
