![]() | Home > Technical (L322) > Can you fit a towbar with a design kit rear bumper?? |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 676 ![]() ![]() ![]() |
Hi,
Brimfull Member Since: 25 Jun 2023 Location: Wrexham Posts: 54 ![]() ![]() ![]() |
Thanks |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I fitted one to mine it does not affect the bumper, I fitted the Westfaila with the swan neck it also will take the farmers hitch.
Brilliant, thanks |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 630 ![]() ![]() ![]() |
I had a similar set up to Tinman on my 2012. The differences were: the underbody cover had 4 screws not two; it had to have a significant sized U shape cut out of it to fit around the swan neck receiver; fitting/removing the cover required laying down on the floor - and its always wet! You can just about see the u cut in this
That looks exactly what I am after. |
Mpx îs right about the four screws and also about cutting out the plastic cover which is defined by a line on the underside, if memory serves me it was a faff taking the cover off because that was where the electrics are mounted |
