Home > Maintenance & Mods (L405) > Reverse light brightness poor
Page 1 of 4 1234>
twintorque
United Kingdom 2016 Range Rover Autobiography SDV8 Siberian Silver
Wife is not impressed with the reverse light output in the dark, to save reinventing the wheel has anyone got a suggested improvement? ( changing the wife doesn’t count ) Previous Discovery 3 she found great of but not the 404 AB
Answers on a postcard please
Post #681730 2nd Jan 2024 9:31pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
I also think this. I never worked out what a good solution should be or where is mount extra lights. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #681848 4th Jan 2024 11:03am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
This came up a few weeks ago, you could try this thread, it's still running.
https://www.fullfatrr.com/forum/topic68652.html
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #681854 4th Jan 2024 2:03pm
this is for a L405 Andy Wink ..
other than extra lighting, be it powered by the tow electrics or an other feed then you're stuck with what you have.
you could switch on the hazards when reversing , this would give you some extra illumination.. ... - .- -.
Post #681855 4th Jan 2024 2:36pm
AndyRoo
apologies, I must read properly, sorry for the confusion.
Post #681859 4th Jan 2024 4:07pm
GaryR
Australia 2014 Range Rover Vogue SDV8 Fuji White
I agree reverse lighting is not good. I have made a bracket that holds a mini light bar that inserts into the fixed tow bar receiver and connects to the tow plug. Obviously works well when not towing, is removable and doesn’t reduce the departure angle.
Post #681884 4th Jan 2024 10:49pm
Gremlin500
Totally agree.
My fatty always goes onto the drive nose first, -to plug in it’s CTEK “heart monitor” Laughing
But when I have to reverse my daily driver truck in, I have the same problem with a pitch black driveway, so just lightly ride the brake pedal whilst reversing, -much better! Not hit the fatty yet! Laughing Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #681893 5th Jan 2024 12:38am
Salsbury
Canada 2014 Range Rover 5.0 SC V8 Barolo Black
I've pondered this too but yet to take action. I think a solution is one of those brackets that holds two LED cubes onto the tow shaft - you can find many on Amazon. Being a range rover, I'd get a pro auto electrician to wire it up.
Example: https://www.amazon.ca/Samlight-Mounting-Br...8&th=1
Post #681933 5th Jan 2024 5:32pm
Martin2
If it's mainly a problem when reversing onto a drive, what about a couple of LED sensor lights? I've got 2 down the side of the house with solar panels on the top, they weren't expensive and are still going strong after about 5 years.
I know that doesn't help when out and about.... MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #681934 5th Jan 2024 5:37pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Do the later facelift rear lights work better?
Post #682061 7th Jan 2024 2:32pm
luxmoggy
I don't think so as it is what I have. I know and have used the brake light to light up behind better.
I am wondering if I put a light on the panel covering the tow-bar. As that can be replaced. SDV8 AB MY 2020
Post #682062 7th Jan 2024 2:38pm
luxmoggy
@stan
The rear led light strip that you fitted does it help with lighting up behind the car for reversing? SDV8 AB MY 2020
Post #682063 7th Jan 2024 2:49pm
zenman63
I fitted a strip led light but have since damaged it and need another cover, the lights ok but snapped the clips on the cover.
It’s wired to the tow hitch wires.
Post #682064 7th Jan 2024 2:50pm
zenman63
Post #682066 7th Jan 2024 3:42pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Sorry - I had my L322 hat on(disregard the bottom unless you have an L322 as well)
I just went down to the shop and the L405 MY16 anyway... would be a bit to get into it. It appears that there are 6 LED 'bulbs' on each side. I will have to look and see if the reverse light are as bad on the L405 as they are on the L322. Because of the nature of the housing, I would say that the best way to go would involve either cutting or possibly just mounting a strip(s) to the lower bumper fascia and wiring into the tow harness.
I know Sam of Sam's Motors and Machines on YouTube did some for his L322
This is a livestream of him doing it...
https://www.youtube.com/live/bDF8xXKLdnI?si=O8FGH0c_liaFcpch
Lord knows I am always game to give something a shot!
These even come with the round adapter that works with the L322... not sure of the L405 reverse lights - I have not cracked that open yet...
https://www.ebay.com/itm/394126416776?_trk...0903.m5276 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #682371 10th Jan 2024 10:48pm
Page 1 of 4 1234>
