Home > Maintenance & Mods (L405) > Reverse light brightness poor
Page 2 of 4 <1234>
Gremlin500
@zenman63:
That looks neat actually, but does it give noticeably more output than say brake lights?
Fancy doing a write-up? Bow down V6 Vogue - “Less is More” - less to go wrong!
Post #682377 11th Jan 2024 12:19am
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
I have the same low reverse light problem but find it helps to see better quite a bit by turning on hazard lights when reversing. Just remember to switch them off after use. RR owner
Post #682462 11th Jan 2024 9:53pm
Old-un
Or ------ how about a brighter light that is wired into a towing socket plugs reverse light terminal in one piece that can be removed when needed for trailer pulling ?
Any body fancy inventing one, I'd buy it.! RR owner
Post #682466 11th Jan 2024 10:18pm
this is old but a goody,
https://www.fullfatrr.com/forum/topic24629...erse+light ... - .- -.
Post #682468 11th Jan 2024 10:26pm
zenman63
England 2018 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Gremlin500 wrote:
@zenman63:
It does light up yes, I need to repair it as it did fit and look factory.
When I rebuild it I will take pictures.
My Trailer rolled back into it and amazing it survived!
Post #682614 13th Jan 2024 5:01pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
I am interested in how and where you wired it in. Looking at the lights available here.
The placement of the light is great. If I am looking at the photo correctly you mounted it from behind the cover and cut a long slot.
I might go for a surface mount where I need to drill 3 holes. One for the wires and 2 to mount. But I will make a version from cardboard to see if it looks funny and sticks out too much. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #682989 17th Jan 2024 1:30pm
Gremlin500
@Luxmoggy:
I “think” you can get the plastic towbar cover cheaply on AilExpress, so a flushmount would then be an option and look much neater? Whistle
Surface mounted anything on a FullFat dear boy? No, no, no! Shocked Laughing V6 Vogue - “Less is More” - less to go wrong!
Post #682999 17th Jan 2024 3:28pm
Gremlin500
Here you go:
For Land Rover Range Rover L405 2013-2018 Rear Bumper Spoiler Skid Plate Protector Tow Hook Trailer Cover Cap LR037895, LR056298
https://a.aliexpress.com/_Ev2uHNT V6 Vogue - “Less is More” - less to go wrong!
Post #683001 17th Jan 2024 3:32pm
Gremlin500
@Zenman63:
How did you fix it to the rear? Bow down V6 Vogue - “Less is More” - less to go wrong!
Post #683002 17th Jan 2024 3:54pm
luxmoggy
@Gremlin500
Thank you for the link. If I order now should get it at the end of February. So have time to choose light and think about the wiring. SDV8 AB MY 2020
Post #683027 17th Jan 2024 8:21pm
luxmoggy
This seems to be the story of my Range Rover. I have a different part. As I have the deployable tow bar, I need a different cover (VPLGB0154), which of course isn't on AliExpress.
I am looking for options now. SDV8 AB MY 2020
Post #683071 18th Jan 2024 1:36pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
I have one you can have for cost of postage. But, postage may be a bit expensive.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #683074 18th Jan 2024 2:00pm
zenman63
It’s wired with a IP rated water resistant plug directly in the tow bar wires, very simple.
Post #683127 18th Jan 2024 7:44pm
zenman63
Gremlin500 wrote:
@Zenman63:
The light comes in an acrylic strip and that needs to curve and the bumper panel is curved, only a bit but it’s not flat.
I then bonded on the back.
It only just fits as there is very little space behind it.
I have ordered a new panel and will mill out another and take some pictures.
Post #683128 18th Jan 2024 7:48pm
luxmoggy
I was looking at the panel today (I didn't take it off). The driveway is still wet and I didn't fancy undoing the screws - I don't want a bad back. But I can see there isn't much room.
@Zenman63
I am thinking of the series 285 light but mounted from behind as you did, as it is thinner. Also, the lens would be more in the cutout. What are your thoughts? SDV8 AB MY 2020
Post #683627 23rd Jan 2024 11:52am
Page 2 of 4 <1234>
