![]() | Home > Maintenance & Mods (L405) > Reverse light brightness poor |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 155 ![]() ![]() ![]() |
I have the same low reverse light problem but find it helps to see better quite a bit by turning on hazard lights when reversing. Just remember to switch them off after use. RR owner |
Or ------ how about a brighter light that is wired into a towing socket plugs reverse light terminal in one piece that can be removed when needed for trailer pulling ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
this is old but a goody,
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 242 ![]() ![]() ![]() |
It does light up yes, I need to repair it as it did fit and look factory. When I rebuild it I will take pictures. My Trailer rolled back into it and amazing it survived! |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
I am interested in how and where you wired it in. Looking at the lights available here.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
@Luxmoggy:
Here you go:
@Zenman63:
@Gremlin500
This seems to be the story of my Range Rover. I have a different part. As I have the deployable tow bar, I need a different cover (VPLGB0154), which of course isn't on AliExpress.
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 300 ![]() ![]() ![]() |
I have one you can have for cost of postage. But, postage may be a bit expensive.
It’s wired with a IP rated water resistant plug directly in the tow bar wires, very simple. |
The light comes in an acrylic strip and that needs to curve and the bumper panel is curved, only a bit but it’s not flat. I then bonded on the back. It only just fits as there is very little space behind it. I have ordered a new panel and will mill out another and take some pictures. |
I was looking at the panel today (I didn't take it off). The driveway is still wet and I didn't fancy undoing the screws - I don't want a bad back. But I can see there isn't much room.
