![]() | Home > Technical (L322) > Losing Coolant - Can't find the leak |
flashheart59 Member Since: 27 Jul 2013 Location: Essex Posts: 25 ![]() ![]() ![]() |
Had this on my 5.0, exactly same symptoms, dried coolant on expansion tank too, think it gets sprayed when drips on belts . My garage tried K-seal too, hasn’t seemed to hurt. In my case turned out to be a small weeping rubber hose on top of engine where supercharger rads are. Took ages to find but easy fix. |
timse Member Since: 06 Dec 2019 Location: Farnborough Posts: 37 ![]() ![]() ![]() |
Many thanks, I'll take a look |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
Yes … go buy a couple of bottles of UV dye, throw it into the expansion tank, run it for a while, and then go looking for the leaks in dark with a UV pen torch after its had a run and is cooling down.
Thanks for this. What dye did you use and where did you get it from please.
CallumOS Member Since: 20 Nov 2022 Location: North East Posts: 2 ![]() ![]() ![]() |
I have had a similar experience with my 2011 5.0SC.
Redtail Member Since: 10 May 2018 Location: Maidenhead Posts: 20 ![]() ![]() ![]() |
Same with my 2010 5.0 SC.
Interesting. Mine really started after my chains were replaced.
