Home > Technical (L322) > Losing Coolant - Can't find the leak
timse
England 2010 Range Rover Autobiography Black 5.0 SC V8 Barolo Black
Hi All,
A tricky one and one my Indie couldn't find.
I have a L322 5.0 SC 2010 (60plate).
A little while ago, I started losing coolant and in the morning or after a trip I would have a pool of coolant underneath.
Took to my indie, and had the water pump replaced. This didn't resolve the problem albeit, coolant was leaking from the pump.
Left the car with the indie who pressure tested and couldn't find where the leak was coming from as the pressure test was fine.
I have not had chance to get it back, as have needed it for work, but, (and I know I am going to get hammered for this Smile ), I put a bottle of K-Seal through to see if 1: It would plug any holes and 2: give a cleared direction as to where the issue might be.
Now, one thing to mention. The leak only seems to happen after the engine has cooled down, and after the k-seal went in, I found that the expansion tank was covered on the outside., so replaced the cap this week, but still seem to have a problem with the leak.
Heating works fine and no other issues other than it seems to only happen when it's cooling down/cold and after it's been driven.
Recent MOT and emissions were fine and no water in the oil.
Short of stripping out the front, I am a little lost on this one, so any thoughts would be greatly received.
Thanks
Tim
Post #682399 11th Jan 2024 11:45am
flashheart59
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Galway Green
Had this on my 5.0, exactly same symptoms, dried coolant on expansion tank too, think it gets sprayed when drips on belts . My garage tried K-seal too, hasn’t seemed to hurt. In my case turned out to be a small weeping rubber hose on top of engine where supercharger rads are. Took ages to find but easy fix.
Post #682467 11th Jan 2024 10:25pm
timse
Many thanks, I'll take a look Smile
Tim
Post #682484 12th Jan 2024 10:16am
fisha
Yes … go buy a couple of bottles of UV dye, throw it into the expansion tank, run it for a while, and then go looking for the leaks in dark with a UV pen torch after its had a run and is cooling down.
Then you’ll definitely see where its coming from.
It could be something like temperature expansion rates being different between 2 components which allowing a leak during temp changes, but re-seals when both parts are the same temp.
I did a thread recently on replacing the coolant o-rings on my tdv8 … maybe something similar on the 5.0 ( I dont have experience of that engine ). I wouldn’t have found the leak without the UV dye. V8 or else ...
Post #682494 12th Jan 2024 12:32pm
timse
Thanks for this. What dye did you use and where did you get it from please.
Many thanks
Tim
Post #682589 13th Jan 2024 12:25pm
CallumOS
England 2011 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
I have had a similar experience with my 2011 5.0SC.
It has just been in for timing chains and the cause of the leak was the oil cooler which sits under the supercharger.
Post #682916 16th Jan 2024 7:30pm
Redtail
Same with my 2010 5.0 SC.
Turned out to be a leak from the oil cooler under the SC. Had the water pump and SC bearings done while it was apart.
Post #682917 16th Jan 2024 7:42pm
timse
Interesting. Mine really started after my chains were replaced.
I'll have to get her back into the garage and have them take a look.
Thanks again.
Post #683083 18th Jan 2024 3:29pm
