![]() | Home > Technical (L322) > CVD calibration or delete |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3336 ![]() ![]() ![]() |
Check continuity on the wiring and examine wiring at the top of the shocks as this is a common fail point. There is a reset function in the GAP IID tool if you replace the ECU module but not for replacing the shock units. 2012 TDV8 Vogue (L322) |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 200 ![]() ![]() ![]() |
At the beginning take a look:
Ah yes I forgot about the 'fake' CVD's out there. 2012 TDV8 Vogue (L322) |
nigor Member Since: 28 Jan 2020 Location: Tallinn Posts: 13 ![]() ![]() ![]() |
Aah then those are fake ones. I changed ”Constant variable damping system” ccf from fitted to not fitted but yeah it gives loads of errors after that. Abs dsc ebd and so on Any clues? |
I checked workshop manuals but couldnt find wiring diagram for active damping module. I tried to put 2.2ohm 5w resistor but it still gives C110E-14 and C110F-14 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
https://www.fullfatrr.com/gallery/albums/userpics/15719/CVD~2.pdf |
