![]() | Home > Maintenance & Mods (L322) > Has anyone tried these LED bulbs? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3382 ![]() ![]() ![]() |
I would also need to buy a new HID bulb and not the old faded bulbs I replaced - not going to happen. 2012 TDV8 Vogue (L322) |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
I'm surprised you need to ask - if you get excessive glare the pick any one of the three. |
You won't - because if an oncoming driver does have an issue with glare from LED lights and "flashes" they get a return retina burning flash back. |
There are no optics in the bulbs it's just a light source - the optics are in the headlight housing The LED light source is in the same place withing the lights optical system as the HID light source What is unsuitable again? 2012 TDV8 Vogue (L322) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
this is my test setup..led is on the right of the pic , xenon on the left..
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1357 ![]() ![]() ![]() |
I've just fitted some Bevinsee DS3 bulbs and I'm not sure which High beam bulbs I need to match them.
I fitted these
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
I also bought the above. No faults on the dash though, no problems so far..
Doesn't show a fault on my dash either - only on the GAP IID fault code scan. 2012 TDV8 Vogue (L322) |
Thanks very much for the info. Going for a drive now to see if the new D3S light up the countryside. |
I am now an LED convert as well. Amazing difference. Going to order the high beam bulbs now. Thanks for the advice. |
The fact that the optics were not designed for the LED light source. |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 568 ![]() ![]() ![]() |
Modern LED's have the light source in exactly the same place as in the bulb they are replacing. It is also a smaller source than either halogen or HID, hence the tighter beam pattern noted in Stan's post.
The LED light source was designed for the optics and works as intended to produce the correct beam pattern. No idea why you are struggling with this..... 2012 TDV8 Vogue (L322) |
