![]() | Home > Technical (L322) > Whistling noise when turning left |
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 ![]() ![]() ![]() |
My blower fan makes a slight squeel when I make a right turn, guessing the bearings are wearing. Could it be the same on yours ?? Also own a 1976 Land Rover 101 3.5 V8.
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Yes that’s a possibility, it’s certainly the right sort of noise. I’ll try with the fan off later and see if that makes any difference, thanks. 5.0 S/C Autobiography - now gone to pastures new.... |
Full marks landy95 ![]() |
GRANGEROVER Member Since: 10 Feb 2022 Location: Bremen Posts: 40 ![]() ![]() |
After my fan started squeezing it took a month for it to stop working... |
I purchased a complete set of wheel bearings 2 years ago when it first started, thinking it must be the ns front. I turned the blower off one day and it was silent. The fan is still working just a bit squeaky on right hand bends. And I have a full set of wheel bearings should the need arise to replace them. I'm glad you found the issue. Also own a 1976 Land Rover 101 3.5 V8. Previously owned 1991 Range Rover Vogue 3.9 V8. |
