Home > Technical (L322) > Whistling noise when turning left
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Got a really strange one on my 2010 5.0 SC AB. When I turn left, I get a sound which is like a faint football whistle which seems to be coming from the passenger side footwell or thereabouts. Only does it when turning left!
Unless there’s a weird noise transmission going on, I’d say it’s definitely not the PAS belt, or the rack (and it’s only left anyway, and doesn’t need to be on full lock for the noise to appear). Definitely seems to be inside the car. Otherwise everything is fine and the car drives perfectly.
Any ideas? 5.0 S/C Autobiography - now gone to pastures new....
Post #682996 17th Jan 2024 3:07pm
landy95
United Kingdom 2011 Range Rover Autobiography TDV8 Sumatra Black
My blower fan makes a slight squeel when I make a right turn, guessing the bearings are wearing. Could it be the same on yours ?? Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
2012 Range Rover Westminster.
1991 Range Rover Vogue 3.9 V8.
Post #683037 17th Jan 2024 10:32pm
Cappo
Yes that’s a possibility, it’s certainly the right sort of noise. I’ll try with the fan off later and see if that makes any difference, thanks. 5.0 S/C Autobiography - now gone to pastures new....
Post #683059 18th Jan 2024 10:30am
Cappo
Full marks landy95 Thumbs Up I tried it this morning with the fan switched off and no noise! Thanks for that, at least it's nothing major, and nothing which a bit more radio volume won't cure!! 5.0 S/C Autobiography - now gone to pastures new....
Post #683078 18th Jan 2024 2:57pm
GRANGEROVER
Germany
After my fan started squeezing it took a month for it to stop working...
Post #683129 18th Jan 2024 8:11pm
landy95
I purchased a complete set of wheel bearings 2 years ago when it first started, thinking it must be the ns front. I turned the blower off one day and it was silent. The fan is still working just a bit squeaky on right hand bends. And I have a full set of wheel bearings should the need arise to replace them.
I'm glad you found the issue. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
Post #683267 19th Jan 2024 11:54pm
