![]() | Home > Maintenance & Mods (L405) > Dynamic Response/ACE filter change |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
You can syringe out the fluid from the reservoir tank, which will then let you undo the pipes to the tank to remove it without too much leaking. Replace the tank and refill, letting it sit for few mins so that any air in the pipes will rise back up to the tank to bleed. Run engine for couple of minutes. Let it sit again, and check the level again. That should be it.
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 268 ![]() ![]() ![]() |
Very useful thanks!
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 153 ![]() ![]() ![]() |
The L322 has the separate ace filter, does the 2016 L405 have a filter integrated within the reservoir? The linked file shows a light shining through the tank, my reservoir has a baffle just below the oil level so the integrated filter comment does seem to be correct.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
Yes the whole tank and filter is 1 item when I got mine changed last year p/n was LR072550
JLR have confirmed that p/n and I've ordered a new (filter incorporated) reservoir along with 2l of STC50519.
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
Pretty sure the L322 doesn't have a separate ACE filter, since it was never fitted with ACE. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
It wasn't on my 2008 L322 but I assumed it was an optional extra since there is a tube video on the ACE setup in a 2006-2009 Range Rover Sport. They did say it was an optional fit. |
Yes, it was fitted to the L320 Sport, but not to the L322 during its life. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
