Home > Maintenance & Mods (L405) > Reverse light brightness poor
Page 3 of 4 <1234>
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Today I had time (and the ground wasn’t wet) - to remove the cover.
Depth there is 20mm, so 18mm realistically for the light. Width I think up to 40-45cm. Height in the lower part of the panel is 30mm.
So I am going to go for the shallower light and get the lens into the cutout.
@Zenman63 If you could post a picture of the wiring that would be helpful. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #683880 25th Jan 2024 5:33pm
Gremlin500
@both:
I’m following you guys on this, very interested.
Zenman63, what did you bond it with, UPVC solvent? i.e. a plastic-weld type solvent, or what?
(ABS plastics can be tricky to bond, and there’s a lot of water & UV light to consider on a bumper).
Pics & a write-up would be vastly appreciated by “The Brethren” , you might even make the Godly annals of the Wiki Hall of Fame Bow down Bow down Bow down Very Happy V6 Vogue - “Less is More” - less to go wrong!
Post #683882 25th Jan 2024 6:14pm
Gremlin500
@Luxmoggy:
Your car is a disgrace, -get it washed! Rolling with laughter Rolling with laughter Rolling with laughter Wink V6 Vogue - “Less is More” - less to go wrong!
Post #683883 25th Jan 2024 6:16pm
luxmoggy
I know, I know... Embarassed
I just ordered a new snow foam cannon. So I hope to try it out soon. I will post a picture after so you can check my work. SDV8 AB MY 2020
Post #683890 25th Jan 2024 6:46pm
Gremlin500
Only kidding, of course my friend 😉😁
Cool, slightly OT I know sorry, but I recently got a new Nilfisk Pro 200 machine with Sno Foam gun, and I love it. The driveway leading to Gremlin Castle is also lookng brand new! 😎 Twisted Evil V6 Vogue - “Less is More” - less to go wrong!
Post #683903 25th Jan 2024 8:34pm
luxmoggy
Cleaned…
Good enough to see my face in it. Laughing
The spare panel has arrived with family in the UK - Thank you @IPG. I will have it in hand at Easter. Have ordered a Hella (2ZR 980 889-011) reverse strip lamp. It should have plenty of room. Next I need to work out the wiring and plugs. SDV8 AB MY 2020
Post #683986 26th Jan 2024 5:24pm
Gremlin500
@Luxmoggy:
Ah! Much better! Very Happy
I'll let you off with a Caution! Laughing Twisted Evil
Nice colour, by the way! V6 Vogue - “Less is More” - less to go wrong!
Post #683996 26th Jan 2024 7:57pm
mjdronfield
Yes, fabulous colour. Not seen that. That’s the sort of thing that might convince me to make the jump…. 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #683998 26th Jan 2024 8:27pm
luxmoggy
The colour is what tipped the scale into my buying my first RR.
But it needs to be cleaned again. The farm tracks leading to football pitches in the villages.
Back on subject:
So I have the light in hand. Next is to work out where to wire it to. SDV8 AB MY 2020
Post #684305 30th Jan 2024 1:09pm
luxmoggy
After looking and thinking about it. I am going to see if I can find the loom plugs so I can create 2 tap-in looms. That means I won’t cut any of the wiring on the car. And it will be easy to remove.
If other people want to also do this. They can easily make their own loom. This is true if they do or don’t have a tow bar. As the plugs are fitted on all cars (I think).
Does anyone which plugs are used? They look a bit like weather pack connectors. SDV8 AB MY 2020
Post #684408 31st Jan 2024 12:07pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
[quote="luxmoggy"]Cleaned…
Yikes! My monitor just cracked!!! Laughing Rolling with laughter
I have some lights on the way... they will be surface mounted... but they are smoked - so I don't think they will show on a Black truck and down that low... The cradle with the screws pops off, so for Proof of Concept, I am planning on some double sided sticky tape and wiring into the 7pin trailer connector.
If the lights look OK, then I will drill the holes in the center panel. I can get a replacement for that relatively cheap off eBay if I ever want to go back.
Slow boat from China - so it will be a while... 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #684437 31st Jan 2024 5:57pm
Gremlin500
@Luxmoggy, @JDGeorgia:
I’m bumping this thread as well, what happened to you efforts, any luck, please? Bow down V6 Vogue - “Less is More” - less to go wrong!
Post #703695 3rd Nov 2024 9:55pm
luxmoggy
I started a new job and haven't had time to spend on this.
I have the parts (the panel and the light). However, I couldn't find the right type of plug to make a breakout patch for the tow bar; I am worried about splicing the wires. A new harness is €160 if I mistake.
Any ideas about who makes those plugs? SDV8 AB MY 2020
Post #703707 4th Nov 2024 6:24am
Gremlin500
Perhaps Zenman63 will pick up on this, and post some pics, or eve do a “how to”?
@ Luxmoggy, do you have pictures of the loom plugs? Presumably this is normally for towbar/trailer electrical connections?
I prefer the idea of flush fit rather than surface mount, would this set-up pass an MOT? V6 Vogue - “Less is More” - less to go wrong!
Post #703710 4th Nov 2024 10:38am
luxmoggy
I plan to cut out the panel so the light will be flush. Depending on the connector, I can always disconnect it and replace the panel. It will then be back to normal.
Studying the documents in the UK and DE, I don't think it will be an issue. The light has the EU/ISO stamp on it. There is nothing about the number just that it must switch on and off at the right times. SDV8 AB MY 2020
Post #703755 4th Nov 2024 7:51pm
Page 3 of 4 <1234>
