Home > Maintenance & Mods (L322) > Headlamp washer fluid brown / rusty |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2695 |
Could be te pump. You can easily replace it by getting acccess through the NS wheel arch by unfastening the liner at the front. 2012 TDV8 Vogue (L322) |
28th Jan 2024 10:43am |
rscsmith Member Since: 07 Aug 2022 Location: Sussex Posts: 26 |
Thanks JayGee. Found them online and only £20, so I'll have a go at that some time and report back. '07 Range Rover Vogue SE TDV8 |
28th Jan 2024 10:54am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
As above, plus, whilst there is one washer fluid reservoir, there are three pumps for the washer fluid, the pump for the headlights is a higher pressure pump, and if I am correct, the headlight washer pump works every fifth time you operate the windscreen wash ( or thereabouts ) so water sits in the pump for longer. There could be some corrosion in this pump, try flushing it through first. It is not a big job to remove the pump. As for opening the pump, it's probably a sealed unit, not expensive to change the pump. The below video will give you more info
28th Jan 2024 11:12am |
The high pressure pump is for HID equipped cars i.e without headlight wipers. Not sure what year HID came in. 2012 TDV8 Vogue (L322) |
28th Jan 2024 11:26am |
https://files.ekmcdn.com/advancedfactors/r...-pumps.png
28th Jan 2024 11:44am |
Thanks everyone for the responses and great information. Looking at the video Merchy posted, the pump being removed in the video had a lot of rust around the bottom, so I suspect I have the same issue. '07 Range Rover Vogue SE TDV8 |
28th Jan 2024 11:48am |
