Home > Maintenance & Mods (L322) > Headlamp washer fluid brown / rusty
rscsmith
Hi folks
The washer fluid coming out of my headlamp washers is brown and makes a mess of the bumper and bonnet. Other than the colour of the fluid, the washers work fine. I think the rest of the car is fine also, i.e. front and rear screen wash is a normal colour.
If it were sediment in the bottle, surely it would affect all circuits. Does anyone have any thoughts on the source of the discolouration and how to fix it?
Thanks, Rob. 2007 Range Rover Vogue SE TDV8 (about to be sold)
2016 (65 plate) L405 Vogue SE 4.4L SDV8
Post #684091 28th Jan 2024 10:39am
JayGee
Could be te pump. You can easily replace it by getting acccess through the NS wheel arch by unfastening the liner at the front. 2012 TDV8 Vogue (L322)
Post #684093 28th Jan 2024 10:43am
rscsmith
Thanks JayGee. Found them online and only £20, so I'll have a go at that some time and report back. 2007 Range Rover Vogue SE TDV8 (about to be sold)
Post #684094 28th Jan 2024 10:54am
Merchy
As above, plus, whilst there is one washer fluid reservoir, there are three pumps for the washer fluid, the pump for the headlights is a higher pressure pump, and if I am correct, the headlight washer pump works every fifth time you operate the windscreen wash ( or thereabouts ) so water sits in the pump for longer. There could be some corrosion in this pump, try flushing it through first. It is not a big job to remove the pump. As for opening the pump, it's probably a sealed unit, not expensive to change the pump. The below video will give you more info
https://www.google.com/url?esrc=s&q=&a...lY3IwfmUNw
Post #684098 28th Jan 2024 11:12am
JayGee
The high pressure pump is for HID equipped cars i.e without headlight wipers. Not sure what year HID came in. 2012 TDV8 Vogue (L322)
Post #684100 28th Jan 2024 11:26am
Merchy
https://files.ekmcdn.com/advancedfactors/r...-pumps.png
The above is from Advanced factors, more info, in case I am wrong, which would not be the first time Whistle Banging Head
Post #684103 28th Jan 2024 11:44am
rscsmith
Thanks everyone for the responses and great information. Looking at the video Merchy posted, the pump being removed in the video had a lot of rust around the bottom, so I suspect I have the same issue. 2007 Range Rover Vogue SE TDV8 (about to be sold)
Post #684104 28th Jan 2024 11:48am
rscsmith
Hi all
Apologies for the long delay in responding. I replaced the pump, eventually, and have left it a couple of months to flush out the pipes, but the issue remains. Think I'll try back-flushing the pipes from the nozzles next, if I can, and see if that fixes it. Failing that, I'll see if I can flush in the normal direction.
Hope you are all having a good bank holiday!
Cheers, Rob. 2007 Range Rover Vogue SE TDV8 (about to be sold)
Post #698782 24th Aug 2024 6:19pm
JayGee
I'd flush out the tank and also check the other pumps are not failing and contaminating the fluid. 2012 TDV8 Vogue (L322)
Post #698805 25th Aug 2024 9:50am
rscsmith
Hi folks
Well, I've finally got to the bottom of this. What I'd already tried:
1) Changing the pump. No effect. I took the old one apart and there's no metal parts in contact with the water.
2) Removing and washing out the washer bottle. No effect.
3) Back flushing the lines. This worked for a week or so, but then the rusty water came back.
Today, I pulled off the bumper and replaced the pipework, and was surprised to find a metal splitter fitting in the middle of it (see photo). I don't know if the original pipework used this type of fitting, or whether someone has added it. Either way, it has certainly had some welding at some point. The new LR supplied pipework has entirely plastic fittings.
Having found this, I'm pretty sure I've found the root of the problem, so hopefully no more brown rusty water all over the front of the car.
Thanks to everyone for all the help.
Best regards, Rob.
Post #716083 13th Apr 2025 8:06pm
