![]() | Home > Maintenance & Mods (L405) > l405 battery |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 507 ![]() ![]() ![]() |
The last 2 mornings I have used FBH before getting into the car. It drops the main battery voltage by at least 0.5V. If the battery is a bit low at the end of a journey I can see this causing issues.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
The auxiliary battery is only switched into the circuit to provide extra current capacity during starting |
Ok. It doesn’t seem to have got to a level where it needs to do so. SDV8 AB MY 2020
The aux. battery should be in circuit during cranking, it's main function is to prevent electrical disturbance during cranking (lights flickering etc.) they were introduced as part of the autostop functionality. |
Last night there was a drain on the main Battery. I don't know what it was - maybe the monitor I have plugged in for the soot. After some time, I saw that the Main and Aux connected together to raise the voltage in the main battery.
The FBH started and then stopped due to the low main battery - that was expected. The AUX (secondary) battery was used to help the main battery start the RR. So it helped jump itself. It was -10C here overnight.
Muiryden Member Since: 28 Feb 2017 Location: Highlands Posts: 3 ![]() ![]() ![]() |
Changed my battery today as it was struggling in the cold. Only lasted 10 years and 210k miles 😮
AnnualMan Member Since: 16 Apr 2023 Location: Zurich Posts: 190 ![]() ![]() |
Do you need to reset the BMS when replacing the auxiliary battery, or just the main battery? 2025 P550e AB |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 ![]() ![]() ![]() |
Each battery has its own BMS control module. It is the chunk of metal on the negative terminal. Chris
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi guys my local garage said my battery may need changing but I got no fault codes or warning on dash etc.. car starts first time no issues here are some reads I took with GAP tool first while engine running after 5 mins second engine off after 5 mins. Are they both due a change even though I’m experiencing no issues?
Jorrocks Member Since: 13 Feb 2012 Location: Shropshire Posts: 55 ![]() ![]() ![]() |
As I don’t have a Gap tool, if I replace my batteries myself will the car start so that I can drive to my Indy for the software bit to be done? 2018 L405 4.4 SDV8 Autobiography
Further to my last post, has anyone managed / bothered to shoehorn an 020 battery into their 405? Same width and height as the standard 019, but 393mm rather than 353mm. 2018 L405 4.4 SDV8 Autobiography
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
My new batteries arrived today - purely preventative maintenance as I've had no issues so far. However, as they are the original batteries and the car is over 10 years old, it does feel like I'm on borrowed time |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1176 ![]() ![]() ![]() |
I replaced my two with the same as Alistair bought, and everything works much better now. overfinch modified |
