![]() | Home > Technical (L322) > Front Blowers and FSR - Next Steps? |
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 34 ![]() ![]() ![]() |
Hi, lots of info on site. Normally a motor problem. There is a really good descriptive procedure on here, it may be in WIKI. For the cost of a motor, I'd just replace. I believe there is a BMW alternative at decent prices |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
Bite the bullet and get a new fan installed
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 88 ![]() ![]() ![]() |
Cheers guys, yes cheap though I think it will take me significantly longer than 5 hours! |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1429 ![]() ![]() ![]() |
When this happened to mine there was also a need to free up and lubricate the moving parts that direct where the heated air goes, sorry to be so non-technical in the description. Only Range Rovers since 1988 |
Thanks CS, the duct actuators(?) seem to be working fine at the moment, however while I am in there it sounds a great idea to lubricate as well. What did you use, silicone grease? |
It was done by the dealers, so I'm not sure, sorry. Only Range Rovers since 1988 |
