![]() | Home > Maintenance & Mods (L322) > Transfer box fluid change |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
That isn't correct and you could end up blowing your transfer box. The diffs and transfer box are exact fill only, not to the plug.
gt40 Member Since: 30 Jan 2013 Location: Cape Town Posts: 31 ![]() ![]() ![]() |
The front and rear diffs must be filled with the correct quantity of oil as stated in post number 2 but the transfer box is filled to the level plug. Below is a direct quote from the workshop manual.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 826 ![]() ![]() |
Thanks Gents
Yes maybe a slight difference in interpretation. The workshop specification says either a wet or dry fill is 1.5L, which should take the level to just below the fill plug, which is what the workshop procedure states.
I just checked with Andy from Glenrands.
