Home > Technical (L322) > Trouble code PO40D-00
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
I was wondering if anyone can point me in the right direction. My new to me 2011 TDV8 4.4 is running fine but has a few minor issues.
I purchased an Autel AP200 code reader and I had five engine codes which were historic and one permanent code PO40D-00 Exhaust gas recirculation temperature sensor A - Circuit high.
This is a permanent code which I cannot delete so I assume the fault is still there. Can anyone point me in the direction of this sensor and any likely causes for the fault? No dash lights or running issues so far.
Many thanks Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #687685 10th Mar 2024 12:47pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
bit of a common fault.... looks a pain to fix, it is on my list to do Sad
https://www.fullfatrr.com/forum/topic50202.html 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #687689 10th Mar 2024 1:38pm
DrRob
Better write up here Thumbs Up
https://www.fullfatrr.com/forum/topic67357.html
Can cause issues for DPF regeneration but random. Best changed though for peace of mind. A new DPF ain’t cheap Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #687694 10th Mar 2024 2:54pm
Buellie
Thanks for that, ordered the part and the socket so will have a go at it when the weather breaks a bit Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #687712 10th Mar 2024 6:16pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Ran mine with that fault for 30k miles no issues but last year had a few red dpf full problems , went round all the usuals and still had it happen again , went through the pita job of changing this at beginning of year so playing the waiting game now to see if it resolves it (140k on car now), fingers crossed for now .
Post #687914 12th Mar 2024 10:26pm
Buellie
Thanks, mine has 160k on it and I am going through all of the fault codes that I have found since the recent purchase. To be honest driving it you cannot tell at all. I will do it when the weather breaks a little. Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #687939 13th Mar 2024 8:38am
GGDR
The original is always the best. I cracked it for the team Smile hahahaha
. Cheers, Greg
Post #687944 13th Mar 2024 8:59am
