Home > Maintenance & Mods (L405) > Unusual Lower Tailgate problem |
WeeJ Member Since: 12 Aug 2012 Location: Aberdeen Posts: 28 |
I have a slightly different lower tailgate problem.
18th Mar 2024 10:20am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
The rubber either side of the lower tailgate controls the opening /closing check if its intact. 2017 SDV8 4.4 silicon silver AB
18th Mar 2024 10:31am |
I wasn’t aware of the gesture part. thanks. 1998 Freelander XEdi
18th Mar 2024 10:08pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1222 |
Hi WeeJ,
19th Mar 2024 12:15am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
I too would recommend deactivating the keyless function... |
19th Mar 2024 12:55am |
Deactivated.
24th Mar 2024 1:09am |
You are right, -if they were activated by closure, it would be the same as an obstruction, and open the gate. Not the desired result! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
24th Mar 2024 12:40pm |
Have you checked your battery SOH?
24th Mar 2024 12:42pm |
